Longer interval options for random parameters
subset
Post by subset »
I often make visuals for slow-moving, ambient music. For this I'm using the 'random' effect automation a lot, but short interval options makes my graphics move a lot faster than I'd like. 8 beats seems like a really low and arbitrary limit for how often the playhead jumps to a new position.
Here's a screenshot pointing to what I'm talking about –
This issue, combined with others related to syncing makes the set feel jittery and unstable as opposed to smooth and synced, and it's more apparent with slower music.
Other sync issues:
Timeline not in sync with effect parameters:
viewtopic.php?f=6&t=20521
Some effects can't be synced to BPM at all, e.g. shift glitch
"Restart" setting on effect parameters doesn't seem to work
When I'm accompanying hard charging 145 BPM techno, these limitations are not so much of a problem, but they are frustrating when working with slower music.
Re: Longer interval options for random parameters
subset wrote: Sat May 08, 2021 00:17 "Restart" setting on effect parameters doesn't seem to work
BPM synced parameters are synced to the composition beat grid by default. (BPM phase lock)
If you'd like to restart, set the parameter Start option to Clip start: https://resolume.com/support/en/paramet ... t-settings
