Using BlackHole and working as I want, except audio not recording with video on my M1 MacBook.
No audio on playback. Sound-driven visuals recording correctly, but no sound output with file. Both muxed and WAV files are a flat-line 0 sound. Audio+video output is on.
Is it one of my missed selections, or is BlackHole incapable? See attached screenshot of prefs.
Not recording audio with video on M1 Mac
FractalMan
Re: Not recording audio with video on M1 Mac
Are you playing the audio in Resolume?
Recording external sources is not possible at this time, but an external recorder like OBS could do it for you: https://resolume.com/support/en/streaming
Thanks @Zoltan, for saying it clearly,
but could you explain why it is not possible to record the external audio source? Or even just redirect the audio-source to output?
In most cases, I want to have the audio IN the movie I record from resolume, because otherwise I will have to start the recording of audio and visual together and then do a crazy job of re-allining. It seems a very basic and necessary feature to have in matter of recordings.
Thanks in advance,
Alessio
Thanks in advance,
Alessio
Because the part where Resolume handles the audio has these not programmed.cocconat wrote: Wed Dec 14, 2022 16:38 but could you explain why it is not possible to record the external audio source? Or even just redirect the audio-source to output?
No audio play through / no audio on Recording
Using Zoom U-24 for audio input.
I am not getting audio on the recording. Audio making it to FFT but none to recorded file.
