Layer Autopilot does not work with BeatLoopr
cocconat
Post by cocconat »
Hello,
I have a Layer with four clips. Each clip has the BeatLoopr on. At the end of the clip loop defined by the BeatLooprs, I would like the Layer's Autopilot to move on and trigger the following clip in my Layer.
But it is not doing so; the clip keeps looping indefinitely; I suspect that there is some End-Of-Clip signal that is not sent out at the end of the loop.
How to make it work? Am I doing/thinking something wrong?
PS.
The BeatLoopr is a very excellent tool! Thanks :)
What is the Catch-Up button of the Beat Loopr supposed to do?
Re: Layer Autopilot does not work with BeatLoopr
Autopilot is fired when a clip is reaching the end point. With beatlooper you make a loop in the clip, so it doesn't reach the end point.
The loop count you can set for the auto pilot refers to the clip looping.
cocconat
Post by cocconat »
Yes, I understand that the AutoPilot is not fired when the clip does not end. But is there any workaround for working with the BeatLoopr?
Is it possible to have as a feature in next versions?
Cocconat
