Audio only play in mono since last update
Anexus
Post by Anexus »
Since last update, (today) audio clips from my composition are just playing the left channel of the clip.
The clips and any other gear are right, if I play it in any other player the stereo soundsystem works well (pc, soundcard, speakers etc).
The only change made in the whole system before this problem appeared was the resolume update.
Please, check it.
Thank you!
Re: Audio only play in mono since last update
Have you checked the PAN settings on the composition, layer and clips?
