Files browser not searching well
itziarG
Post by itziarG »
Hi all!
I'm new at the community, but a long time Resolume user.
I have a simple but annoying problem since I switched from Mac to Windows.
When I search for files in Resolume's internal file browser from words, it doesn't find them. Neither on the internal hard drive, nor on the external one.
Does anyone know why this happens? It didn't happen to me when using Resolume on Mac.
Thank you very much!
Re: Files browser not searching well
Could you give some examples with screenshots, on what doesn't work?
itziarG
Post by itziarG »
Hi!
Thanks for your response. I think I didn’t explain my issue very well, so I’ll try to clarify:
The problem is not that Resolume’s internal file browser doesn’t search at all, but that it only finds files inside folders that are already expanded in the file browser. If a folder is collapsed, its contents won’t appear in the search results. And the software by default opens with the folders unexpanded.
This didn’t happen to me in the past, so I have organized my material in many subfolders. I’m wondering if something has changed in Resolume or if I’m missing something.
Is this the expected behavior, or am I doing something wrong?
Thanks again!
Hmm, I see what you mean,
We'll see what can be done to improve this.
