lag, crash, problems with finding the files
JohnSchmidt
Post by JohnSchmidt »
after testing a cracked version of resolume 6 that was loosing the files all the time, that was very often crashing and often showing no images in output whereas it said it was playing clip, I decided to buy this expensive software.
How wonderful :
- it loose a bit less the files (on a ssd usbc linked to the laptop) but still it happens
- when opening the software it tries to run the previous composition but then crashes. I have to open another composition first and then open the one I was working on.
- sometimes there are lags in the video (I assume it could be my configuration witch is still pretty good, also I only play 3 layers of videos and no animation or 3D stuff generated by the software ; could also be that the 7th version is slower than the 6th on my computer)
anyway
I feel very disapointed
Re: lag, crash, problems with finding the files
Are you using DXV video clips or mp4?
What kind of computer?
