Drag and drop
rawdesigns
Drag and drop
Post by rawdesigns »
I've been noticing when I run Resolume 7.17.3 in administrator mode in win 11, I am unable to drag and drop files such as .png into my composition. I get the red circle with the slash through it. When I drag from the "Files" tab in Resolume it works fine.
Re: Drag and drop
Yes, elevated privileges app can't access normal privileged resources.
rawdesigns
Re: Drag and drop
Thank you. Im running as administrator because if I don’t, I randomly get a drop in FPS for a few seconds then my FPS goes back to normal. I have Arena added to the list of nvidia programs and set to max performance
Re: Drag and drop
Interesting, I wouldn't think that running as admin would give higher priority or stability to applications.
But you can change the priorities in the task manager. Task manager might also show that other app is putting load on the system when FPS falls.
