Resolume won't open
joryenright
Resolume won't open
Post by joryenright »
Hi, I have a weird problem on two identical machines, where the latest version of windows and Resolume installed won't post Resolume now.
I've tried uninstalling windows updates and reverting to an earlier version of Resolume, however no luck.
Same issue on both machines (Windows 11, i9, A5000, 2TB SSD).
Any help would be appreciated.
Thank you again
Re: Resolume won't open
Could you give us more info to work with please?
I have similar machines as you listed and they're working fine so I'm thinking it must be a difference in hardware or other software installed.
Do you have a working audio device selected in preferences?
Files synced to cloud?
