Access to the recording while it's being recorded
AlisaKo
Post by AlisaKo »
dear all,
is it a way (in Avenue or Wire) to access the recording while it's being recorded? I want to access the footage (live feed), which is currently being recorded in a 2min file, after several seconds of the start of the recording. is there a way in Resolume?
thanks!
Online
Re: Access to the recording while it's being recorded
Check the folder you have set up for recoding, it should have the files stored instantly, but you might not be able to drop them to your composition until they finished writing.
If you have lots of VRAM, you could make a Wire patch which stores the frames of your capture clip into memory, and rewind there. Two minutes rewind would require a lot of VRAM though.
