Arena 7.22.3 latest bug?
Masiwei
Post by Masiwei »
Why does 7.22.3 crash? It crashed several times overnight and doesn't work properly. I still have 700gb left on my C drive. Sometimes it crashes almost every eleven minutes and no crash report pops up, only TEMP popups. I only put 400 videos or pictures in DXV3, MP4, TURBO, PNG formats. Can anyone tell me how to fix this? :| :| :|
Masiwei
Re: Arena 7.22.3 latest bug?
Post by Masiwei »
@Team Resolume
EBMCreative
Post by EBMCreative »
Your using an NDI source?
I had this this too. It was caused from me using NDI
Masiwei
Post by Masiwei »
I use 5 4k cameras, do NDI acquisition wirelessly, and output to arena using vmix. Is it not possible to output in this way? If so, how to solve it?
EBMCreative
I don't know how to fix it.
I only know this happened to me a few weeks ago using the blackmagic ATEM web capture into resolume and I was having problems. So I used NDI tools to capture the Webcam source and then used the NDI source in resolume and after a day or two I started to have this happen.
When I tried to figure it out I noticed in my event viewer that it was having tcp/ip problems. I tried a few things but it never fixed.
How does the RAM usage look like when you see the issue?
EBMCreative
My ram usage was about 30-40%.
It happened with 7.21 and 7.22.
EBMCreative
Masiwei wrote: Fri Jan 24, 2025 23:15 Why does 7.22.3 crash? It crashed several times overnight and doesn't work properly. I still have 700gb left on my C drive. Sometimes it crashes almost every eleven minutes and no crash report pops up, only TEMP popups. I only put 400 videos or pictures in DXV3, MP4, TURBO, PNG formats. Can anyone tell me how to fix this? :| :| :|
What OS are you using?
Masiwei
Post by Masiwei »
Win11 ,This has nothing to do with win11. When I delete the Ndi from the arena source in the layer, the problem can be solved! Maybe the camera uses wireless acquisition to cause the error!
