edit text parameter in resolume
Jingle
Post by Jingle »
I think i've found a new bug.
I've made a swf file using the text parameter .
but if i wan't to edit the text parameter in resolume it works fine.
But now, if you use backspace a several times it crashes.
you type somthing like "ROCK" , en you press backspace 10 times or somthing, resolume will crash.
is this problem in my swf file or is it a resolume bug ??
i think it's in my swf file becausse the sample's don't have this problem.
can someone help ?
running on Xp pro
nvidia geforce 6600GT
pentium4 3 Ghz
2GB Ram
thnx.
If you want i will post the log file.
yes please create and post a log file seo we can see where it crashes.
Jingle
Post by Jingle »
Logging started: dinsdag, 05 juni 2007 - 10:41
start up 5/06/2007 10:41:29
create my documents folder if not exists for current user 5/06/2007 10:41:29
create application data folder if not exists 5/06/2007 10:41:29
check direct x version 5/06/2007 10:41:29
check if flash is installed and version 5/06/2007 10:41:29
init: previewer 5/06/2007 10:41:30
init: decks 5/06/2007 10:41:30
init: file browser 5/06/2007 10:41:30
init: fx 5/06/2007 10:41:30
init: sources 5/06/2007 10:41:31
init: preferences 5/06/2007 10:41:31
load avaliable MidiInput devices 5/06/2007 10:41:31
Init Midi Controller list 5/06/2007 10:41:31
Init Midi Notes list 5/06/2007 10:41:31
Init Key list 5/06/2007 10:41:31
Init Audio Capture device list 5/06/2007 10:41:31
Load settings 5/06/2007 10:41:31
Set Midi Input devices 5/06/2007 10:41:32
Init DMX 5/06/2007 10:41:32
Save settings 5/06/2007 10:41:32
gather preferences 5/06/2007 10:41:32
gather channel keyboard shortcuts 5/06/2007 10:41:32
save preferences and keyboard shortcut settings 5/06/2007 10:41:32
gather midi shortcut settings 5/06/2007 10:41:33
get midi channel/ layer shortcuts 5/06/2007 10:41:33
copy midi channel/ layer shortcuts 5/06/2007 10:41:33
copy midi controller shortcuts 5/06/2007 10:41:33
get midi effect shortcuts 5/06/2007 10:41:33
get midi channels 5/06/2007 10:41:33
save midi shortcut settings 5/06/2007 10:41:33
save dmx settings 5/06/2007 10:41:33
init: shortcuts and midi 5/06/2007 10:41:33
init: recording 5/06/2007 10:41:33
init: audio fft 5/06/2007 10:41:35
init: render 5/06/2007 10:41:36
init: bpm 5/06/2007 10:41:36
init: screensetup 5/06/2007 10:41:36
firsttime get displays 5/06/2007 10:41:36
firsttime copy display setups 5/06/2007 10:41:36
finalize screen setup 5/06/2007 10:41:36
destroy screens 5/06/2007 10:41:36
create screens 5/06/2007 10:41:36
search main dxdraw 5/06/2007 10:41:36
set dxdraw resolumedraw 5/06/2007 10:41:36
position mainscreen 5/06/2007 10:41:36
check for dvdmax 5/06/2007 10:41:36
set global settings for multi and single screen 5/06/2007 10:41:36
initialize all screens 5/06/2007 10:41:36
dualscreen is false 5/06/2007 10:41:36
initialize dxdraw 5/06/2007 10:41:36
--------------begin intialize-------------- 5/06/2007 10:41:37
creating overlay if needed 5/06/2007 10:41:40
create surfaces 5/06/2007 10:41:40
width:320height:240 5/06/2007 10:41:40
create vidnet object 5/06/2007 10:41:40
create spectrum surfaces 5/06/2007 10:41:41
create watermark surface 5/06/2007 10:41:41
create system surfaces 5/06/2007 10:41:41
create system preview surfaces 5/06/2007 10:41:41
create directshow movies 5/06/2007 10:41:41
create vfw movies 5/06/2007 10:41:41
check quicktime and create movies 5/06/2007 10:41:41
check for capture devices 5/06/2007 10:41:41
create dibs for pictures 5/06/2007 10:41:41
create picture objects 5/06/2007 10:41:41
create picture dib objects 5/06/2007 10:41:41
create plugins 5/06/2007 10:41:41
create flash 5/06/2007 10:41:41
again try dvdmax if not created and if supported 5/06/2007 10:41:41
get bltcaps 5/06/2007 10:41:41
--------------end intialize-------------- 5/06/2007 10:41:41
assign additional screens to resolumedraw engine 5/06/2007 10:41:41
position displays 5/06/2007 10:41:41
set screen setups 5/06/2007 10:41:41
start render engine 5/06/2007 10:41:41
render engine started 5/06/2007 10:41:41
init: load startup decks 5/06/2007 10:41:41
getPreview D:\program files\resolume 2.41\demofootage\70-80-90\scroll708090editable.swf 5/06/2007 10:41:55
read preview from disk D:\program files\resolume 2.41\demofootage\70-80-90\scroll708090editable.swf 5/06/2007 10:41:55
read preview success D:\program files\resolume 2.41\demofootage\70-80-90\scroll708090editable.swf 5/06/2007 10:41:55
preview was succesfull D:\program files\resolume 2.41\demofootage\70-80-90\scroll708090editable.swf 5/06/2007 10:41:55
i'll post the .fla file later. i think the problem is in the fla file becausse the demofootage sampels don't crash.
