All FX and blending modes lost
tristangieler
Post by tristangieler »
I think I'm going crazy. I just updated to version 3.1.3, having succesfully used the older versions' effects and blending modes. Now all of them are gone. The effects list is empty in resolume, both for VST and FFGL. The blending mode tab reads "no choices". When I go to (/Applications/Resolume Avenue 3.1.3/plugins/vfx) I find the whole list of effects, but they're all unusable apparently.
Please help.
Re: All FX and blending modes lost
Hey Tristan
That's some strange behaviour. Have you tried restarting your computer or re-installing Avenue?
BTW, weren't you supposed to be in class when you wrote this? ;)
Check the Video Preferences and make sure the the FFGL plugins directory points to the correct folder. That should fix it.
