DXV Files Not Playing Properly
Culturecide
Post by Culturecide »
Hi, I exported all my footage to DXV, and first I noticed all 16:9 was squished to 4:3 and nothing could fix that,
second I noticed all my DXV files playing back distorted in Resolume - see image below:
here's what i mean (image attached)
DXV playing back weird / distorted
I outputted with quicktime DXV codec from adobe premiere cs4, resolume says the files are 872x480
i will try exporting as square pixels and see how it goes
.. the files play back normally in quicktime / media player classic
Culturecide
Re: DXV Files Not Playing Properly
ok i think i got it
trying to export with aspect ratio of 16:9 with DXV caused the problem i think
i tested square pixel clip seems to work ok. now time to re-export everything !
edwin
Post by edwin »
DXV has to encoded in square pixel ratio, so yes unfortunately that means a re-export ;-)
