Drop Shadow FFGL filter
vjsmad
Post by vjsmad »
hello dear developpers
Because it seems not so difficult , could we have a little contribution to the freeframe community users from you to have a shadow FFGL filter. I mean something like the perspective shadow filter in after effect. With opacity, direction, distance et softness parameter. Should be to apply in real time for moving object , flash text, everything
with alpha channel and transparency to add deph with shadow projection on the background.
thanks to think about that ))
take care
laurent
shadow filter.JPG (1.72 MiB) Viewed 62695 times
GeeEs
Re: shadow FFGL filter
Post by GeeEs »
I'm not a developer, but it sounds to me like a great idea! :!:
I've had that exact same idea in the back of my mind for a while now. I use a lot of pre-rendered drop shadows with DXV footage, and on the right screen it adds a really nice sense of depth. Just need to find the time to make the effect ;-)
vjsmad
Post by vjsmad »
So please Take The Time )) should be easy with a good glsl library
no?
We were a bit fed up with programming boring stuff today so Dani wrote this drop shadow FFGL plugin ;-)
Enjoy!
DropShadow_FFGL_Windows.zip
(149.94 KiB) Downloaded 6725 times
DropShadow_FFGL_Mac_OSX.zip
(73.62 KiB) Downloaded 6120 times
vjsmad
Post by vjsmad »
wow The good news of The day , thanks guys
i Try it as soon as possible
" i dream it, Resolume did it "
GeeEs
Post by GeeEs »
:D Haha... great response from Resolume HQ! Works quite well here... Just did a little test with flash text and DropShadow plugin!
Tino
Post by Tino »
Resolume always comes through with the madness. Very much appreciated! :D
vjsmad
Post by vjsmad »
after some test i CAN say it works good but I have some suggestions
- should be better to have a transparency parameter and a softness parameter
to choose if the edge of the shadow are smooth or not and if it's full black or not
it should not exactly the same result as actually
and could it be possible to have more choice for the distance to add more depth
finally I don't see something happen with size shadow parameter
thanks for all )
vjsmad
Post by vjsmad »
when distance is set to 0 you have a stroke around the text or anything else but it's interesting effect
