Resolume 4.1.3 + Madmapper 1.4.2
Madmapper works as it should only resolume keeps crashing.
Only generated clips and DVX
Computer specs:
iMac mid 2011 3,4GHz, 16GB, HD6970m 2GB, 256 sad, 2TB HD
Os X 10.8.2 (Just freshly installed)
How I can prove more information to fix this?
This is so bad that going to the gig is not option.
I found also that resizing clip resizes layer mask. This happens with sources also. Resizing source (ie solid color) size resizes layer mask also.
