can't play dxv codec on OS X (in the system player)
ewerx
Re: can't play dxv codec on OS X (in the system player)
Post by ewerx »
QTAmateur can play DXV on Mavericks. Doesn't fix quicklook but at least you can double-click to preview things.
http://www.mikeash.com/software/qtamateur/
basvcds
Post by basvcds »
I'm using Quicktime7 for now, but i sure do hope there's a fix on the way for this. Not being able to use quicklook makes it tedious to quickly scan my library while on a gig.
http://support.apple.com/kb/dl923
Thelooca
Post by Thelooca »
Is there a know emailadres or contactpage where we can stalk apple with the question to resolve this?
Programfeed
Post by Programfeed »
Thelooca wrote:Is there a know emailadres or contactpage where we can stalk apple with the question to resolve this?
http://www.apple.com/feedback/macosx.html
edit: included quote for context
adriancuervo
Post by adriancuervo »
Something new about this topic? What player/previewer do you use on Maverics? I've just recieved a new mac and downgrading is not an option, just a patch, and it's a dirty solution limited on time. Any suggestion for the future that is coming? Maybe a plugin for quicklook? An independent previewer?
Thanks for your work!
jim
Post by jim »
https://github.com/Marginal/QLVideo
quicklook plugin to view 3rd party videos, have not got time to deal with it at moment did not work straight away, think you have to assign mov's to play back by vlc or other application that supports DXV, though might be set up to play back on the container name (.mov) but the tech is there and if your files are not in mov container should work.
**edit
more info here
https://forum.videolan.org/viewtopic.php?t=115308
.lov.
Post by .lov. »
I have a Quicktime based thumbnail generator here, works well with DXV: https://github.com/lov/QLVJ/
A technical note here: QL plugins cannot access to the window server, which means generating thumbnails for QC compositions does not possible. QL plugins has no way to render animated content, like video, so at the current state of the QL architecture making a working DXV/HAP/whatever QL-previwerer is technically impossible yet.
