can't play dxv codec on OS X (in the system player)
dmnik111
Post by dmnik111 » Fri Oct 25, 2013 05:59
Hello.
I have some issues with playing dxv files in mac. in premiere and resolume all good, burin system all players shows 00.00 time and "can't play this file". Can anybody help to improve that?
Re: can't play dxv codec on OS X
Post by Joris » Fri Oct 25, 2013 10:13
On OSX 10.9 Mavericks, Apple has decided ( in their infinite wisdom ) that it currently does not support 3rd party codecs for the system players.
DXV encoded files will play fine in apps that support the old version of Quicktime, but not in Quicklook, Finder or Quicktime Player X.
We're not happy about this at all, but for the moment our hands are tied. Apple has shut out all 3rd party devs for native system video playback...
pfelberg
Post by pfelberg » Fri Oct 25, 2013 12:53
Does this mean that soon DXV files will also not be played by Resolume itself with Macs running Maverics or the new version of QT?
Post by Joris » Fri Oct 25, 2013 13:14
Of course not. Resolume will always be able to play DXV files.
pfelberg
Re: can't play dxv codec on OS X (in the system player)
Post by pfelberg » Fri Oct 25, 2013 17:25
What about encoding DXV from other applications as After Effects and Final Cut Pro?
VJsynC
Post by VJsynC » Fri Oct 25, 2013 17:31
The encoding works, iv'v just tested in compressor 4 and MPEG Streamclip with mavericks and the latest version of compressor!
About the thumbnails and quicktime playing i'm curious about what you guys will do about this, there has to be a solution for this, it's your codec, i can't be waiting a toon of month without not being able to "see" my library or "preview" it with fast view!
nokipowlonski
Post by nokipowlonski » Thu Oct 31, 2013 17:10
Hello,
Yes, it's a big problem, really.
Please consider our request.
Post by Joris » Fri Nov 01, 2013 09:54
We know this is a very big problem.
The situation is that Apple has closed off playback of DXV (and all other codecs aside from a few Apple ones) inside the system player. This is because internally they have started using a new playback system.
There is absolutely nothing we can currently do about this. Only Apple can decide to open up the system player again in the future.
If your workflow depends on Quicklook and Quicktime Player X, the only option you have is to downgrade back to 10.8.
Rene
Post by Rene » Fri Nov 01, 2013 13:16
Well, this is a very good reason for not to upgrade to Mavericks. Thanks Apple! What if a company like Microsoft would dare to do that... I really loved the idea of native tags in finder. Will continue to use PathFinder :)
Thanks for starting this thread!!
ewerx
Post by ewerx » Sat Nov 02, 2013 15:45
Any way to use another player like VLC to play DXV files?
