Low Memory, Crash
toananh84
Low Memory, Crash
Post by toananh84 »
After using for 30min -1hrs resolume shows low memory status at the bottom and it is going to blow up if i dont reset the software or reload the composition.
I use .mov file, 5 - 7 layers, 16 column, few flash file, no 3rd party software, no audio, no internet,
My computer specs
Intel Core i5 4670K Unlocked Quad Core 3.4GHZ P
Gigabyte Z87X-D3H
Kingston SSDNow V300 120GB 2.5in SATA3
Kingston SSDNow V300 240GB 2.5in SATA3 L
EVGA SuperNOVA NEX750B 750W ATX EPS12V Power Supply 80PLUS Bronze
ASUS BC-12B1ST Internal 12X Blu-ray Reader & 16X DVD Writer Combo Drive SATA OEM
Kingston KHX1600C9D3B1K2/8GX 8GB Kit 2X4GB 1600MHz DDR3 240PIN
MSI GeForce GTX 770 OC
He2neg
Re: Low Memory, Crash
Post by He2neg »
Check if osc (send / recive ) is turnd off
This should have been fixed in patch 4.1.8 i think but its worth a try.
~Berlin~
make sure your .mov files are dxv encoded.
I would love to see where you got this information. According to our notes, the last OSC related crash fix was on 4.0.1.
He2neg
Post by He2neg »
i try to find the topic but i guess i wont, i had this memory overflow on 1 show as well and then i read somewere in the Forum about it and there it was. i try to find it....
i can remember :
if osc (send / return) is eneable but no ipad ( or whatever) is there to respond it will overflow the memory soner or later.
~Berlin~
Every time I got a low memory issue was because I was using media that was not encoded with the DXV codec. Even very small files could overload the system if there are many layers and rapid triggering so make sure ALL you movies are DXV.
He2neg
Post by He2neg »
@ Joris :
maybe i mixed somthing in my own memory, but i guess the topic i think of is this :
viewtopic.php?f=12&t=10640&p=42187&hili ... eak#p42187
~Berlin~
Thanks for looking it up.
In general, 99% of the time, low memory is caused by using too many non-DXV files.
OSC has never been confirmed to cause a memory leak.
toananh84
Post by toananh84 »
i will check OSC and movie codec tonight at the club sorry I was out of town for the last few days.
toananh84
Post by toananh84 »
Last night i convert all my video into DXV codec i only have them in .MOV before, so i use this tutorial to convert evething into DXV codec http://www.instructables.com/id/How-to- ... -Resolume/ so far so good only problem i have right-now is if the clip include music then it very laggy i need to turn off or delete audio then the video is running smooth again
