Remove this
Kadete
Remove this
Post by Kadete »
Hello i'm having some trouble to understand this :
Same composition, same active clips and effects (mostly auto-mask, drop shadow and one FFGLVolume):
4.2.0: 43~45 fps
4.2.1: 8~9 fps
when i disable the effects Drop Shadow and FFGLVolume, i get 60fps (V-Sync) in both cases
Hope someone can help
Re: Resolume 4.2.1 Bad Performance with some effects
Is it the combination of Drop Shadow and FFGLVolume that cause the problem, or is it one of these effects in particular?
Kadete
Post by Kadete »
nevermind was Nvidia settings on 4.2.1... what a difference a small tweak does
please remove this topic
