Keyboard Shortcut
adam2972
Keyboard Shortcut
Post by adam2972 »
Hello all!
Not sure whether this is a simple question or not...
Is it possible to create a keyboard shortcut to a clip or column in a different deck? I can only seem to do it within the deck.
(For reference I am trying to use Stream Deck as a controller with hotkeys)
Many thanks
ps If I was to just use one deck with multiple columns (eg 500) would this slow everything down?
Empyfree
Re: Keyboard Shortcut
Post by Empyfree »
I don’t think I so. I don’t think decks really “exist” until you switch to them.
Online
Might as well join the team
Right click on the clips you plan to use on other decks and change the clip type to "persistent " Keep all your persistent clips in columns 1-xx and then start your other clips past where the persistent clips end.
