Quotation from the manual: "In order for BPM Synced clips to work right, you will need to set the number of beats that the clip spans in the Transport section. By default, Resolume will guess the right amount of beats for you based on the length of the clip. It will guess to the nearest power of 2, so it will set the clip to 1, 2, 4,
8, 16, 32, 64, 128 etc beats for you."
When I import a 7 s clip from the explorer to Resolume, Resolume guesses 16 beats duration, regardless of the tempo of the composition. Why does the 7 s clip which is imported in a 240 bpm composition get 16 beats duration (it should be 28 beats), and the same 7 s clip imported in a 60 bpm composition gets 16 beats duration, too (it should be 11,7 beats)?!? 28 should be rounded up to 32 beats, and 11,6 beats should be rounded down to 8 beats.
By the way - Resolume guesses the duration to the nearest power of 2. With long clips, there can be a huge
difference to the "real" duration of the timeline mode, which makes the clip run much too fast or slow.
it would be nice to have the option to guess the duration with a multiple of 2 (or 4, 8, 16...), not with the power of 2. I admit that most of the time you will have durations with the power of 2 in a usual music arrangement, but sometimes you don't...
