Make Videoplayer-Npde show Seek as input.
KingKongsy
Post by KingKongsy »
I was wondering why the videoplayer in the example-file shows "Seek" and so on as an input but when I generate a new videoplayer-node, it doesn´t.
How do I make the input appear on a new videoplayer-node??
Edit: another question concerning "Seek": why is the input an event and not a number?
Might as well join the team
Re: Make Videoplayer-Npde show Seek as input.
Can you right click the node and look under "visibility"
KingKongsy
Ah great, thx.
