Wire Randomize Node
vhsdestroyer
Wire Randomize Node
Post by vhsdestroyer »
So recently I have been doing a lot of randomized modulation of strings and have been running into an issue. Because the randomize node expects events at the trigger, it is also expecting event based numbers for min and max.
A specific instance where this becomes an issue:
String in--------------------------------------Read Word
String in--count word--/--random (max)------Index
In this example, the RANDOM max should be updating to the number of words in the STRING so that all words are a possible outcome as the RANDOM node indexes the string on the READ WORD. But the random node expects events so the min and max cannot be modulated by float or integer values. In fact the random min and max cannot be connected to any meaningful point of modulation and must be updated manually to define the range.
I'm not sure if this is an issue that can easily be fixed because the random node is an event based node, but it would deliver a lot of interesting results if the ins accepted floats and integers.
ladylalonde
Re: Wire Randomize Node
Post by ladylalonde »
I hope this finds you well.
I assessed the same bug yesterday and would greatly appreciate if this could rectified in the near future.
Thank you for your contribution and hard work,
Love and respect :mrgreen:
Might as well join the team
Try adding an "On Change" node in between what you want to change the value and the 2 nodes.
vhsdestroyer
it works! can't believe I didn't try this. Thanks @Arvol
