sleepytom wrote:
Werlin - could you expand on that please? what settings do you make in resolume to see the knobs working? Do you know if the APC uses the same NRPN controller as the MPD32?
when you rotate the knob resolume's left side should turn into something like this
i went through all the modes.. absolute jumped left or right, 0-127 kept going one way no matter to where i turned the knob (unless i checked invert then it would go always the other way...), react i really dont remember and i already got the apc20 ready to ship back (but i dont think it worked either)
but relative 63-65 mode worked fine, bumped the steps to 500, checked the loop option and it was working properly
as for nrpn i know nothing about that... but i saw a while back some technical specs pdf on midi notes and messages of the apc40 on the vjforums, dont know if they're on akai's webpage though
(cant find it in my web history but a quick search back on the forums and you should find it quickly)
