360° video FFGL plugin for resolume?
fernandomartin77
Re: 360° video FFGL plugin for resolume?
Post by fernandomartin77 » Sat Jan 21, 2017 04:43
Hi everyone
This is my first post and it is because I found this subject so important to me.
I need to do exactly the opposite.
I have videos in 360 format dual-fisheye MP4 file, example: https://www.youtube.com/watch?v=Qa4veMMmvvk
In resolume I want to mix videos in this format normally, and that final mix will convert it to equirectangular format.
I need equirectangular format on the output.
I hope I have explained correctly, and I await your comments
Thank you!
francoe
Post by francoe » Fri Feb 10, 2017 23:35
Are you try'ed the shaderloader with the code posted? Maybe can modify it to your own needs.
markbres
Post by markbres » Sat Feb 18, 2017 02:13
BlueMD wrote:EASIEST SOLUTION FOR 360 VIDEO or IMAGE
Just apply a Stingy Sphere effect on top of the source equirectangular image/video. Then:
Sphere Size: 1
Extrusion: 0
Zoom: 1
Resolution: 1
And feel free to play with the rotations =)
Next up, synchronize 4+ spheres with the same content input on each, but outputting a different "face/section" of the sphere to achieve a full surround image output for 4+ projectors.
WOW this works pretty well ! THX :) too bad you can't control the FOV to zoom in or out on the inside.
DanielArnett
Post by DanielArnett » Thu Mar 16, 2017 20:43
Okay, I've been wanting the same thing for a while so I wrote one myself.
Introducing 360 VJ, a plugin for Resolume to rotate a 360 video in realtime.
damstraversaz
Post by damstraversaz » Fri Mar 17, 2017 09:26
that's really a great tool, thanks a lot !
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
lightbx
Post by lightbx » Sun Mar 19, 2017 16:02
Arnett, you are the MAN! Great work! Thank you so much. This will come in handy for sure on a gig I have in April.
francoe
Post by francoe » Tue Apr 18, 2017 10:50
@DanielArnett try'ed your plugins, they're just amazing. Personally never have the need of this filters, but I love to see people solving the everyday's troubles in that fancy way. Many Thanks.
Babcom
Post by Babcom » Tue Apr 18, 2017 18:08
Hey there DanielArnett! Thanks for your effort in getting live video in to the 360 world : )
I wonder if you could implement a "tiny world" feature in your little tool box. It would be fantastic to play with in real time...
All the best.
DanielArnett
Post by DanielArnett » Wed May 03, 2017 03:53
Wish I got notifications for these replies. Glad you like the plugins. I'll try to find time for the little world and double fisheye effects. And post them here.Just need to figure out what the little world effect is in mathematical terms.
AndriiShramko
Post by AndriiShramko » Sat May 06, 2017 15:49
Hi! Need your help.
How to export video from resolume in the equirectangulars format?
Here is my post with video examples.
viewtopic.php?f=14&t=14380
I am a professional in the VR 360 video shooting and VR 360 editing. I also can help you in the different questions in the VR video shooting and editing.
