360° video FFGL plugin for resolume?
someone thinks it's possible to have a ffgl plugin for resolume that transforms a 360° videoclip (equirectangular) like facebook and youtube does? you could have parmeters like: field of view, camera position, camera rotation, ... would be an effective but simple plugin for 360° content.
						Re: 360° video FFGL plugin for resolume?
Yes. This would be sweet to have! What kind of source would you have Markres (cameras, lenses, capture cards)? I have a similar idea for a projekt...
+1
						+1
				fruitygreen
Very possible.
Tried "Polar Coordinates " plug in with a few of my spherical videos , some time ago in Vvvv. It needed better way of controlling, but as proof of concept it was kinda working.markbres wrote:someone thinks it's possible to have a ffgl plugin for resolume that transforms a 360° videoclip (equirectangular) like facebook and youtube does? you could have parmeters like: field of view, camera position, camera rotation, ... would be an effective but simple plugin for 360° content.
working with vvvv and 360 video content is super easy! did that just load texture on a sphere and stream with spout to resolume. that was the reason i thought it is so easy to do that and pack it into a simple ffgl plugin. with a simple plugin you could have many 360 layers in resolume on top of each other.
				vj Lambency
if this has not been done yet, I am thinking of taking it up...
Any more info what you guys want... Can someone send me a clip for testing, also what markers and girds should it have?
				SucculentHam
I am presently building content for dome projection. I develop content within After Effects using Camsphere as demonstrated in this tutorial.
https://vimeo.com/125726168
Dome content can also be tested using SATDomePort2.0 .
Hope this helps.
Ham
Hope this helps.
Ham
I need a little more info to get started on this.
The clips you be loading are equirectangular panorama video clips?
And you want a view placed on that so you can look at a section of that panorama.
Also the panorama will need to be mapped on a sphere.
View movement you want left, right, up, down, zoom in / out?
I hope i got that right, please let me know if something is not right.
Can you give me a demo clip for testing.
				fruitygreen
You can find a sample of equirectangle footage here.https://www.entapano.com/en/l/panorama.html
Controlling the view could be possibly like how GoPro VR (formerly KolorEyes) does it. https://vr.gopro.com
Of course you would want it with mappable controls, midi/Osc.
Krpano.com can produce Flash tours with your 360videos. You could then mod them to play in Resolume. Haven't tried it but it's worth a shot.
FYI:TouchDesigner uses a template and can do live VR. Via PtGui template.
https://www.derivative.ca/Forum/viewtop ... =22&t=7979
Controlled with Occulus. Maybe just easier to Spout Out of it. TD that is.
sounds great! camera inside the sphere mapped equirectangular panorama video clips.hive8 wrote:I need a little more info to get started on this.
possible parameters:
-camera rotate x, y, z (look left-right, look up-down, roll angle)
-camera field of view (degree)
-camera or sphere move x, y, z
-sphere rotate x, y, z
-sphere size/radius
-sphere resolution/detail?
yes you look at a section. camera could also be on the outside of the sphere and look at it.
