I just got started with FFGL Plugin development and I created a super basic source that creates a border for the screen. I applied the slice transform effect to it because I wanted every slice to have this border and noticed that it doesn't render my source for every slice but just copies and transforms it for every slice. My problem there is that this is a projection mapping with multiple slices with different aspect ratio.
As this could be useful for multiple sources and effects I would like to know if there is a way to render a Clip and all of the effects applied to it for every slice?
I would also create an FFGL effect that does this by myself but I don't know if this is possible at all since I don't know if there is a way to access the whole effect chain of a clip so I can tell it to render for every slice.
