Capture a remote steam
smudge1977
Post by smudge1977 »
I want to steam a remote computer into a resolume capture source.
I think somthing like this is what i want:
http://www.rtpstream.com/cgi-bin/mwf/to ... w.pl?tid=9
so I can then use VLC on a remote machine to steam to an rtsp stream and then have a capture device in resolume that is the remote screen. This will then allow somebody to send me power point slides to be keyed over a live camera feed via a llindy composite to USB adapter.
anybody got anything like this working?
Smudge
vjsjarcie
Re: Capture a remote steam
Post by vjsjarcie »
I've been testing with an blackmagic intensity pro pciXpress card to get an external laptop screen into Resolume.
Blackmagic cards are natively supported by Resolume and indeed its works like a charm!
Maybe this will get you the same result.
