Hello,
after the enthusiasm of first uses, some little observations and suggestions for improvements, including the "Advanced Output Settings" interface of Arena ...
Is it possible for future updates of Arena to integrate the Keystone Mask (+ Crop?) tool to the Interface directly into the "Advanced Output Settings > Output Transformation", which would be able to hide areas at the output after mapping projected surfaces. Because if we uses a mask in the composition before the advanced output settings, it makes it impossible to clone a zone if just one of the surfaces to map requires a mask.., which I find considerably limits the possibilities of mapping complex structures...
Also editing tools point (bezier) should give us a way to create more complex masks that limited adjustments of current Keystone Mask, and without leaving Resolume to create it with Photoshop or other ...
Why not also include presets for primitive forms of these masks (circle, triangle, ...) ...
Another thing that would be nice, it would be that we can have a magnetism points in the Input Selection Mode and Transformation Mode for fast and accurate adjustments. I know I can have this precision with giving the coordinates of each point but it is very tedious for a complex mapping ...
Finally, and I'm not the first to ask for it I think, the ctrl+Z function will be greatly appreciated when it becomes possible to implement it..!
For information, but you know it, and it's not to screw you over (uhmmm. .. ), the IRMapio plugin integrates, it seems to me, all the improvements mentioned above, so for those who, like me, have chosen moving to Arena I think there are still some improvements but I am sure that this will happen, you're used to it now ..
Thanks for your works, Resolume still the best
Pascal / V.JaX
