Thanks for sharing your thought on this, Joris and leolodreamland!
As I just returned from vacation, my reply is a bit delayed, so please don't take this as an indicator for (un)importance of this issue. Also: I had to download 4.1.2 before!
goto10 wrote:when will the autopilot trigger for a clip like this
Let's ask her.
Maybe we tell the auto pilot to take either audio or video timeline, or the one which is longer/shorter. But I agree such an extension could raise some other questions. But I really think it's worth discussion it!
The doubling appraoch of leolodreamland would also be okay, but I think it does not solve the open questions, does it?
goto10 wrote:be counterintuitive for most users
I agree on that. For that reason this should be hidden behind some kind of 'advanced timeline setting'. Maybe have one master timeline (equivalent to the timeline now) and two additional sub-timelines for audio and video linked to the master? I'm just thinking loud, not sure if this would work. Or what about grouping of clips?
goto10 wrote:this will have to be done with two clips.
This is not a solution, as it means I have to use the column trigger to start video and audio at the same time. And it also allows for only two clips per column. I think it means I have to prepare the clips before - which takes away the live experience and a lot of flexibility.
goto10 wrote:So no
The last word?
So there won't be support in Resolume which allows to create one A/V clip of one long audio snippet and one relatively short video loop?
