...or, Mobiola Web Camera for iOS device + free PC/MAC receiver/recorder application. Turns iPhone/Pod into WiFi cam. Feed can be recorded directly on computer while also being used as a source in Resolume.DirtySoap wrote:If you want a wireles setup from a camera you can use an Iphone (or multiple) and airbeam. It supports Syphon and has verry little latency. this you can use as a source. Mac only.
Go-Pro Hero 3 Black ed./ live stream vid/Resolume
Re: Go-Pro Hero 3 Black ed./ live stream vid/Resolume
I've see a very smooth stream from this tutorial that opens the WIFI location in Quicktime player instead of VLC. Now it may bot be 1080p but I mix live at 720p. So how could we get the Quicktime stream to show up in Resolume Sources? As long as we can get 18-25 frames per second it would work for my needs.
https://www.youtube.com/watch?v=WqEzyWMFQtg
Resolume 4+ Supports Syphon
ENABLE Syphon in your preferences.
After more research I found this thread
http://v002.info/forums/topic/syphon-qt ... am-inputs/
There is another app that converts SLR cameras into live USB cameras.
Syphon Live Cam
https://github.com/v002/v002-Camera-Live
Syphon Live Cam
I want to do this but with my 60d, where can I find a tutorial to add a video stream to my resolume project
				alfaleader
Gopro through wifi stream is worthless and unusable. Tried it with a 4 black, but resolution is very very low and latency too high to be any good.
A better option is to use an android phone with the app IP webcam. There is a syphon app for ip camera's.
Hi, may I ask how you did that, I just can't get my Hero 4 Black to stream video over wifi to my mac ....alfaleader wrote:Gopro through wifi stream is worthless and unusable. Tried it with a 4 black, but resolution is very very low and latency too high to be any good.
