clip BPM changing
Re: clip BPM changing
The other question ;-)
goto10 wrote:Is setting the clips to beats maybe an option for you?
mowgli
Post by mowgli »
sorry, I hadn't seen that. I'm not sure, what will the difference be?
Well, the difference between BPM and beats is that instead of saying at what BPM it should play, you say in how many beats it should play.
The result is the same: the clip plays in a certain tempo while listening to the master BPM. Hopefully an additional difference will be that you do not get the BPM value changing behaviour.
