Edit: oops - i found under 'sources'... Ok, so i 'Play' with that...
New FFGL Plugin: audio waveform via fugScopeGL
Re: New FFGL Plugin: audio waveform via fugScopeGL
Hm, i bought it right now, but i don't know how to use it in Resolume. I just copied the DLL into the VFX Folder, but i can't find the effect in the effects list. Do i have to do anything else?
Greetings from Germany
Rainschn
Rainschn
Do somebody have same plugin for Resolume 7? Can't find it...
The bigfug plugs are no longer supported, I doubt it will function in Resolume 7 because there was some change to the FFGL protocol? but there may be something similar or even better? ie on getjuice?SHAGALOV wrote: Sat Jan 25, 2020 11:43 Do somebody have same plugin for Resolume 7? Can't find it...
