osx mavericks
Re: osx mavericks
Anyone having crashes or beachballs on Mavericks or any OS, please contact us directly via the Feedback tab of the preferences.
Re: osx mavericks
Just updated to Maverics, updated software as well.
Crashes non stop.
Huge huge bummer.
Had 7 crashes in a 2 hour show.
When triggering columns especially. It stops showing all of the clips, just shows one, then crashes.
FML
Crashes non stop.
Huge huge bummer.
FML
Re: osx mavericks
And yes, DXV no longer previews in Finder.
Are there any fixes to Resolume in works? I am right in the middle of a tour... so this is very unfortunate.
Re: osx mavericks
Just for kicks, clicked a few more columns while Resolume was stuck on showing just one layer... The entire OS started flashing broken glitches, Resolume crashed, Mac kept flashing broken patterns for about 20 seconds after, all of the finder windows, etc were just going completely berzerk
Re: osx mavericks
My OS info (see screen shot). Solid state drive. Mac Book Pro, version right before Retina I think... a year or so before that one came out.
- Attachments
- Screen Shot 2013-11-14 at 3.02.04 AM.png (27.31 KiB) Viewed 11682 times
Re: osx mavericks
Yikes. That's not good.
Could you contact us directly? You can do this via the Feedback tab of the Preferences.
Re: osx mavericks
If you press "more info" then it should say the exact model (mine is a "Mid 2010" for example).zebbler wrote:My OS info (see screen shot). Solid state drive. Mac Book Pro, version right before Retina I think... a year or so before that one came out.
Re: osx mavericks
Or you can contact us directly, and the logfile will tell us all we need to know
Re: osx mavericks
I contacted you directly.
Does the log file contain info on the last few crashes?
Let me know if there are any particular tests you want me to do, I will do whatever it takes to get it back to working....
Re: osx mavericks
Let me crash it a few more times and send you more direct feedback. Maybe it'll improve the log files for you
