Clip random duration
skydeck
Re: Clip random duration
Post by skydeck »
basically what i want to do in autopilot mode is the following:
on one layer I am running a background-video or some live-feed from the party. This should be overlaid with some abstract clip-loops in the next layer, some effects being linked to audio fft. To avoid getting boring, the abstract clips should change, say every 30 seconds. So I would like to load that layer with any clips I choose, set their duration to 30 seconds and let autopilot random them through. I know I could pre-process the loops to 30 secs. length. But a duration setting would be so much easier and I have always been wondering why it isn"t there :D
RycoDePsyco
Post by RycoDePsyco »
English:
Please let at autopilot "individual" or "all" Clips repeated several times before the next clip is playing.
Thank You
German:
Bitte bei Autopilot "einzelne" oder "alle" Clips mehrfach wiederholen lassen bevor der nächste Clip abgespielt wird.
Danke
subpixel
Post by subpixel »
I'd like to set the number of times a clip loops before autopilot action. Some loops are very short (one bar, maybe even one beat) and it is silly to have to render out a longer clip made of copies.
Another option I'd like to see is autopilot after a fixed duration (time or bars), eg every 30 seconds, independent of clip lengths.
Thirdly, I'd like to have a buttons for "one-shot" autopilot actions: previous, next, random. At the moment the only way to do it is turn on autopilot (forward, reverse, random) and subsequently turn off autopilot.
Sadler
Post by Sadler »
Here's a little processing sketch:
nClipLen is the length you want the clips to play for in seconds and nMaxClip is the number of clips you want to cycle through.
Code: Select all
// start OSC config
import oscP5.*;
import netP5.*;
/*portToListenTo, port we are listening on, this should be the same as
 the outgoing port of TouchOsc on your iphone
int portToListenTo = 7001;
/*portToSendTo, port we are sending to, this should be the same as
 the incomning port of Resolume 3, default it is set to 7000, so you wouldn't need to change it.
int portToSendTo = 7000;
/*ipAddressToSendTo, ip address of the computer we are sending messages to (where Resolume 3 runs)
String ipAddressToSendTo = "localhost";
OscP5 oscP5;
NetAddress myRemoteLocation;
OscBundle myBundle;
OscMessage myMessage;
//end OSC config
int nClip = 1;
int nClipLen = 5; //length of clips
int nMaxClip = 10;//number of clips to cycle through
String sAddress;
void setup() {
  frameRate(1);
  oscP5 = new OscP5(this, portToListenTo);
  myRemoteLocation = new NetAddress(ipAddressToSendTo, portToSendTo);
  myBundle = new OscBundle();
  myMessage = new OscMessage("/");
void draw() {
  boolean send = false;
  int nSec = second();
  if (nClip > nMaxClip) {
    nClip = 1;
  if (nSec % nClipLen == 0) {
    sAddress = "/activelayer/clip" + str(nClip) + "/connect";
    println(sAddress);
    myMessage.setAddrPattern(sAddress);
    myMessage.add(1);
    myBundle.add(myMessage);
    myMessage.clear();
    nClip++;
    send = true;
    /* send the bundle*/
    if (send)
      oscP5.send(myBundle, myRemoteLocation);
    myBundle.clear();
    //wait a sec
    while (nSec == second());
carnzoid
Post by carnzoid »
subpixel wrote:I'd like to set the number of times a clip loops before autopilot action. Some loops are very short (one bar, maybe even one beat) and it is silly to have to render out a longer clip made of copies.
I would like to see this feature too! I always cut my loops to be as small and efficient possible. With the downside that they're very short when played with auto-pilot.
elgarf
Post by elgarf »
+1 for clip repeat number.
