[vvFFPP] 7 new freeframe plugins for free ;]
vvarp
Post by vvarp »
so here comes a update :cool:
2005.01.12
NEW: vvCutMix and vvDynaMask plugins for hosts that can provide multiple inputs to fx. (in other words - its unusable for resolumers...)
FIX: vvCutStop and vvMaskStop rewritten from scratch for better performance.
FIX: Minor performance fixes in vvStripe and vvStretch.
FIX: All Plugin ID strings now uses same scheme (VV??).
SITE: Plugin list updated with new samples and descriptions.
go here: http://freeframe.visualvinyl.net
[Edited on 2005/1/12 by vvarp]
Anonymous
Post by Anonymous »
thanks again
will try these friday
the two new ones look great.
respect
Ruud
Post by Ruud »
thanks!
Resolume can use multiple input plugins!
But only 2 inputs and the first parameter is used to slide from the 1rst input to the second. These plugins are used to mix layers and for the opacity/wet-dry-mix of effects.
vvarp
Post by vvarp »
whoa! i didnt know about this ;)
in this case vvCutMix should works without any problems!
Anonymous
Post by Anonymous »
great
;):cool:
Anonymous
Post by Anonymous »
nice work mate,resolum'ers who want to use the other parameters could use Petes Free Chain to rearrange the parameter order and to change the default values too,kind of like presets:)
vvarp
Post by vvarp »
i am afraid that my plugs are not yet ready for PetesFreeChain... its only my theory - do someone make any tests with them?
edwin
Post by edwin »
hi vvarp,
to be able to use the freeframe plugin in petes free chain you will have to support the processframeCopy functionality.
only then will they be useable, and i think (but i might be wrong) that your plugins have to support 32 bit.
Cheers
Edwin de Koning
vvarp
Post by vvarp »
thanks edwin,
i am quite new in freeframe world and everyday i learn something new about this ;)
32bit support is there already and processFrameCopy should be easy to achieve trough copy/paste ;)
is there something else what i sholud know about freeframe support in resolume?
i was really surprised that 2-input plug can be used to mix between decks... ;)
