HOW TO??? one button "bumps".
Kadete
Re: we got it... :)
Post by Kadete »
He2neg wrote:
Smulider wrote:
GREAT AND HOW
+1
okp
Re: HOW TO??? one button "bumps".
Post by okp »
yeah, +1 !!
tutorial please...
I got bored during a musical show I where was mixing the sound here you go pure resolume:
The bump is assigned to the X key, have a look at the composition key mapping and you'll get the idea for midi.
one bump on key press, one bump on key release.
get it here: http://palffyzoltan.hu/?url=programs&a=one_button_bump
dirtyjohn_lv
Post by dirtyjohn_lv »
Here's a crude solution using 1 layer (1 hour of work).
You will need
Bome's Midi Translater 1.8 https://www.bome.com/products/miditranslator (not sure if the translator file is backwards compatible)
FRParameters FFGL plugin http://www.1210visuals.net/index.php?op ... &Itemid=58
Midi Controller
I used a Launchpad Mini for testing, you can using any controller with buttons, just have to change the incoming messages in BMT to match the button you want.
You will need 2 virtual port out of BMT for this to work. Make sure you have both ports active in Resolume preferences.
To map in Resolume:
Disable the Opacity Bump Preset, go into mapping mode in Resolume and map your button to the Alpha of the Solid Color. Make sure Velocity and Piano are selected. Set Alpha to 0 on Solid clip
Disable the Clip Bump preset and Enable the Opacity Bump Preset, then map each FRParameter Opacity on each push of the button you want. Make sure you have Velocity and Piano selected for each one. Set each Opacity to 0.
Enable the Clip bump again and you should be good to go!
https://drive.google.com/file/d/0B7mXx- ... sp=sharing
Bump 720.zip
(4.14 KiB) Downloaded 860 times
Just because it fit's here perfectly!
Badass Joris just recently released a wonderful plug-in called "Chaser". Now we can say our friends that we surely join them when they ask us to watch the new Star Wars movie in cinema because we need much less preproduction time for our coming jobs. Nailed it!
Facebook Video: Wait what?
Facebook Joris: Video
Me checking out the CHASER Demo with a live input:
You can try and buy it here: Hybridvisuals
Enjoy
juicewon
Post by juicewon »
just found that myself.
awesome work joris. pretty straight forward even if a bit pricey.
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
The price is inversely correlated the amount of work that's needed to get the one-button-bumps working. I did all the hard work for you, so that's reflected in the price.
Really, I encourage everyone to *not* buy my plugin and tinker around and set things up yourself. Basic programming is an awesome skill to have and more power to you if you make it work. Dirtyjohnlv's solution is a great starting point, and requires very little extra work.
If you don't have the time, skills or just don't feel like getting your hands dirty, you can get my solution which works plug and play, natively in Resolume, without the need for Bomes running in the background. And it does a whole bunch of more fun stuff that you know you want to be able to do ;)
okp
Post by okp »
hi dirtyjhon_lv,
I tested your method and the result pretty cool.
but i have a question, in your rules of BMT have 3 bumps command, how if we put another bumps maybe 1 or 2 more bumps, how to write the rules..
thanks for helping
BUMPS !
dirtyjohn_lv
You would have to add more bumps to the opacity on rule and just change the g0 and nn variable
Keep in mind you have to to use FRParameter to add more physical bumps to your layer.
nn send the variable to the outgoing midi note, so any more bumps you add to Opacity On, you would also have to change Clip On because I made that 3
Change this to be 1 higher than number of bump
Code: Select all
if g0>=6 then g0=1
Add more bumps
Code: Select all
if g0==4 then Goto "bump4"
if g0==5 then Goto "bump5"
Label "bump4"
nn=3
g0=g0+1
exit rules, execute Outgoing Action
Label "bump5"
nn=4
g0=g0+1
