Spacers between parameters
hive8
Re: Spacers between parameters
Post by hive8 »
Looks like u need the following VC2015 dist
http://www.microsoft.com/en-us/download ... x?id=48145
Kadete
Post by Kadete »
Looks very good!
On mine Resolume Arena 5 the plguin don't show on tab "effects". How i can do troubleshoot?
edit: hehe just saw the 2nd page now :p i''l try again tonight.
hive8
Post by hive8 »
Are you on Windows?
Did you install the MS VC2015 like in the link provided above, x86 version since we are running 32bit.
Kadete
Post by Kadete »
I had already installed. I unnistall and install, but still keeps not showing.
hive8
Post by hive8 »
Kadete wrote:I had already installed. I unnistall and install, but still keeps not showing.
Can you send me a PM with your email so i can get in contact with you. It might be quick to help you.
Kadete
Post by Kadete »
I'm in the process of switching laptops next week. I'll contact you if do not work with the new one ;)
hive8
Post by hive8 »
Kadete wrote:I'm in the process of switching laptops next week. I'll contact you if do not work with the new one ;)
What laptop are you getting?
Kadete
Post by Kadete »
I don't think it's relevant to the thread, but is a MSI G70 17.3'' Stealth Pro with 3 outputs that support up to 4k (2x DP, 1 HDMI). Just bought today, I hope that was the right choice.
Edited: Worked
hive8
Post by hive8 »
Hi all, got my OS X machine back, please find below the compile version for OSX
FFGL4Screen.bundle.zip
(9.29 KiB) Downloaded 639 times
francoe
Post by francoe »
Works Great over win, I will try the osx version soon.
Thoughs beyond your needs:
What about blend modes between the 4 stacked textures? Or maybe something like Auto Mask filter.
What about a global size control for all textures, and an envelope control between them?
As example, global size set first texture to a size, then 'envelope' control set the fourth texture size, and the other two take size values between. As Shift RGB does on z scale.
I'm thinking in a simple replicator to stack the four textures in Z, with scale control and blend.
