Resolume 1.1 beta 2 is out!
ill_
Post by ill_ »
I had the same problem with the scrolarrow of the browser, but you better take the scrollbar with the mouse and move it without the scrollarrows, it doesn't make the output freezes.
I just want to say that resolume 1.1 beta2 it's really good, i have tested live and no problem, everything all right, and videospeed incredible.
But i have the problem that when i have an effect applied and i apply another for example tile or tilemirrored it goes on number 20(at the maximum value) not 4 as i put in the initial value.
And it don't read me the preferences, it puts failed initializing variables.
And finally, just an idea, i could be good if mousecontrolled effects could go varieting automatically and you could control the velocity of this variation, like a video but with the effects, it would be gr8.
thanks for all men!
cyberlight_
Post by cyberlight_ »
The new version is so much faster, some good new features too, and the most robust VJ app we use - the only thing that gives me real problems is trying to unload and reload a vfw/wdm source - is that Resolume or my drivers or what?
Two new killer features please - motion blur and hue shift - have a look at Lightgroove http://www.audiovisualizers.com/toolsha ... groove.htm - I bet you could do that :)
Sterling work gentlemen!
vj iv0_
Post by vj iv0_ »
Hello,
I have tried beta 2 and have to say it's very good. I did not noticed any promised speed improvement on my Matrox G400, but the new features are worth it...
I have only one problem, which was not at ver. 1.0:
On my Crystal sound card I could not make MIDI working, so I changed the soundcard for SB128. Then I could see the MIDI device, but touching MIDI controller leads to Resolume crash. I have no problem with both of those soundcards with Resolume 1.0.
aah damn this nasty midi bug is causing a lot of problems ... we are trying to find a sollution but the problem is that we can not reproduce the crash here with our computers and midi hardware and that makes debugging very hard ... but we are trying!
vj iv0_
Post by vj iv0_ »
If you are interested, my setup is:
P4 1,6 GHz
ASUS P4S533 (SIS Chipset)
Matrox G400 MAX with RainbowRunner
SB 128 Vibra Sound Card (could not make the midi work with Crystal CM8738 and beta2)
256 MB of DDR RAM
Windows 98SE
By the way, I think that everybody would really appreciate detailed description of your testing PC and midi hardware you are using...
Thanks for Resolume - it's an ace program.
