random lagging during video playback
Re: random lagging during video playback
Any chance you could share one of these clips?
pette
Post by pette »
I have the same problem.
Also with small clip.
All clips are in dxv 3 - 1280x720.
it appears random even if I have no effect e no transparency
Mac book pro retina 15" - NVIDIA
vjhummer
Post by vjhummer »
Hi Oaktown,
Have you already resolved this issue? i'm working on a Videoinstallation as well and having similar problems with stuttering playback.
The FPS shows 59 to 60, i play two clips of 1024 x 768 DXV 25 FPS and audio on both clips.
AMD Radeon HD6950 2gb Sapphire
Windows 7 Arena 4
If you found something please let me know!
Regards, Nils
SteveG2000
Post by SteveG2000 »
i took my comp and footage to another computer. initially running on a windows 10 PC (with an 8Gb quadro card) and moved it to a macbook pro. there was no lag on the MBP with the same comp + footage. the only difference i had was that the pc was connected through minidisplay -> DVI to the monitor an the MBP with HDMI -> HDMI to the same monitor.... i suspect it has to do with that... but not sure.
pette
Post by pette »
Arena 5.0.4
SSD
Nvidia GT 750M 2048 MB
When I play my videos sometimes they freeze for some seconds.
The Fps counter is around 60
when it freeze is about 30
it freeze in local test.
the video are 1280x720 and 30 fps with dxv codex 3.0.1
thanks
pette wrote:Hi,
Arena 5.0.4
SSD
thanks
which osx version are you using?
on my 2012 mbp, I had an issue like yours, where the video card would just freeze for a half second or so like every 30 seconds even with google chrome, but only after upgrading to Yosemite.
On mavericks and el capitan everything is smooth until I play 8-10 HD layers.
drazkers
Post by drazkers »
Is your content 25fps and your screen set to 60?
What happens when you change your outputs to 50hz?
Martians
Post by Martians »
I have also just noticed this lag on my Samsung EVO 850 2TB - super strange.. I'll switch to another SSD asap!
deepstrut
Post by deepstrut »
i had a simular issue. check your memory usage in the task manager. i found every time framerate dropped memory would increase. would continue until memory warning appeared. disabling OSC data has appeared to solve the issue.
drazkers
Post by drazkers »
Martians wrote:I have also just noticed this lag on my Samsung EVO 850 2TB - super strange.. I'll switch to another SSD asap!
This reminds me of a tour i had, back at the start of the year! The mention of the 850 jogged my memory.
I had a raid 0 with the samsung 850 pro as well. We would get random lagging, i switched our content to our OS raid 1 and finished the tour.
I returned the drives, was given new ones and everything was fine. I believe there is a batch of 850's out there that randomly lag out. I used some benchmarking tools and you'd be at 750MBs and suddenly it would drop to like 25.
Everyone should do a disk test if they notice random FPS drops.
