Give option for OUTPUT MONITOR to display mapping from ADVANCED OUTPUT (with example)
Re: Give option for OUTPUT MONITOR to display mapping from ADVANCED OUTPUT (with example)
yochee wrote:Too bad previewing the mapping and screen distribution - whats actually playing - only if you use external plugins like Visution Mapio or Joris' Chaser (or if you leave open the advance output).
connect another monitor to your system and enjoy full screen monitoring of your projector output:
yochee
Post by yochee »
ravensc wrote: connect another monitor to your system and enjoy full screen monitoring of your projector output:
why should I bring another monitor, when there is a software solution possible?
a hardware solution with another monitor is not what I am seeking for, as the output monitor with x layers blending without mapping in the Resolume GUI doesnt make sense at all. All these layers plainly overlayed in the output monitor are distributed to different areas in the advanced output. so the only information we get from the output monitor is that there is clips playing (but not if they are playing in the mapping and so on).. so it's not a good final solution to work with
