After Effects 17 doesn't show DXV 3 Codec
hive8
Re: After Effects 17 doesn't show DXV 3 Codec
Post by hive8 »
Where is the DXV3 codec installed on a windows 10 system?
Seems i found it
C:\Program Files (x86)\QuickTime\QTSystem
ixikos
Post by ixikos »
I am still struggling with this one. Are you only moving the DXV3Codec.qtx file to the QuickTime\QTComponents folder?
ixikos wrote:I am still struggling with this one. Are you only moving the DXV3Codec.qtx file to the QuickTime\QTComponents folder?
Which Adobe version are you using? https://resolume.com/support/en/no-dxv- ... be-cc-2018
tatoaraoz
Post by tatoaraoz »
Hi Guys,
I find a temporal solution.
This happen to me only in version cc2018 15.1
Downgrade to 15.0.1 allows me to render in DXV and other 3rd party codec.
dunie
Post by dunie »
The only solution for windows, please install Quicktime too... 100% clear
dradutu
Post by dradutu »
tldr reinstall resolume.
happened to me too, cc 19 and 6.1.3. my guess is because i installed resolume first and then premiere. tried reinstalling just the codec a few times with no result, then i uninstalled the codec and resolume, restarted and installed resolume and now the codec is there [i guess a simple resolume reinstall would suffice, but that's how i did it]. there's a checkbox for premiere & ae when you install resolume, i guess if it doesn't find an install path it skips that.
dradutu
Post by dradutu »
also, we're at version 3.01 for the codec and 7.02 for resolume, update that 4 on the codec installer :)
dradutu wrote: Fri Sep 13, 2019 10:59 tldr reinstall resolume.
Correct, if you don't have premiere or AE installed, you probably don't need the export plugin ;)
