Can't open my recent purchase of Resolume Arena 6
pit_stolkysbit
Re: Can't open my recent purchase of Resolume Arena 6
Post by pit_stolkysbit »
ravensc wrote:Osx has a bug, where sometimes the Installer.app won't correctly open a .pkg if you double click it.
If this happens, you can open the Installer.app directly and select the package in the file dialog.
http://osxdaily.com/2016/07/26/fix-stuc ... -mac-os-x/
OOOhh !!! thanx man !! it's really works :lol: was so easy !
but mac pro 2013 is another problem :shock:
as in attachment, and I cant click any button in it *facepalm*
Снимок экрана 2017-09-19 в 23.31.05.png (50.32 KiB) Viewed 11679 times
you can find the crash log in /Users/YourUser/Library/Logs/DiagnosticReports
and also please upload your Documents/Resolume Arena 6 folder if it got created.
You will only be able to attach these in a Zip file.
pit_stolkysbit
ravensc wrote:you can find the crash log in /Users/YourUser/Library/Logs/DiagnosticReports
DiagnosticReports is empty, but i've got a log file, may be it could help ...
pit_stolkysbit_res6_log+doc.zip
(3.11 KiB) Downloaded 579 times
barthvis
Post by barthvis »
I have the same problem and found that it is user related. When you create a fresh user and login as that user and start Resolume 6 it will startup OK. So it must be a preference related problem... But which pref do I have to delete?
borisfoong wrote:Just recently purchase my copy of Resolume Arena 6, installed it, opened Arena 6 and my first attempt was to try to get into preferences and key in the serial for registration. But instead the software hung for a moment and immediately shuts down.
Please try again with Beta2, thanks!
mygeneration
Post by mygeneration »
barthvis wrote:I have the same problem and found that it is user related. When you create a fresh user and login as that user and start Resolume 6 it will startup OK. So it must be a preference related problem... But which pref do I have to delete?
2011 MacBook Pro
I was able to replicate this issue; Area 6 hasn’t worked since the release of Beta 1. I removed all previous files and verified disc permissions, fresh download/install, opened Arena 6 Beta 2, Problem Report opens instantly and crashes.
Logged out of my account, opened guest account, started Area 6 works as expected.
b_man
Post by b_man »
Similar problem here, 2013 MacBook. I hear a loud click from the speakers and Resolume quits before the splash screen. No error report comes up. Attached is the log file. Hope it helps.
AvenueCrash.zip
(62.3 KiB) Downloaded 555 times
b_man wrote:Similar problem here, 2013 MacBook. I hear a loud click from the speakers and Resolume quits before the splash screen. No error report comes up. Attached is the log file. Hope it helps.
This one is specific to Avenue, should be fixed in beta3.
Does this still happen with the release version?
cyndamoore
Post by cyndamoore »
Hello,
I am experiencing the same issue but with the Avenue 6 software. I have tried to download and restart my mac multiple times, but each time I try open the Avenue 6 it crashes and I get the dialog attached. I've looked into my security settings for third-party app permissions, launched installer manually, redownloaded, restarted but this has not worked.
I have also attached my mac specifications and crash log.
Please let me know how I can get it to open up.
Cynthia
Screen Shot 2017-11-08 at 9.59.59 PM.png (23.9 KiB) Viewed 11513 times
Avenue_2017-11-08-220004_Cynthias-MacBook-Pro.crash.zip
(20.15 KiB) Downloaded 548 times
