4k gui resolution EDID issues
Re: 4k gui resolution EDID issues
We're working on it.
In the meantime, if you disable scaling in windows, you should get the correct resolutions.
sachismo wrote:Please let us know if there is any headway being made on this, as this is curently the main thing keeping me from ugrading my whole production to R6! And I really want to
Keep in mind this is still beta, have a look at this post viewtopic.php?f=11&t=14856#p62185
sachismo
Post by sachismo »
Hey,
Thanks for the response! Sorry if I was seeming impatient, just dying to use all of the new features for our show.
And after your tip I did get it working as expected! The fix is just different than my fix that worked before on Arena 5.. So for anyone having this same issue I will post the process that now works for me:
1-With output screen(s) connected, right-click on desktop to open Windows display settings.
2-Make sure "Change the size of text, apps, and other items" is at 100% for all outputs including main GUI display
3-If you have disabled display scaling in resolume properties, uncheck it to set back to normal. Otherwise this step is not necessary
4-Restart computer! These setting do not seem to take effect until restart.
5- That should be it!
Both my systems now currently have pixel perfect outputs as expected!
And an extra added bonus is that I can now use Windows display scaling ont the GUI screen during a session if Resolume or other programs are too small on your high DPI display! (Just make sure it is set back to 100% before restart!)
I'm sure future updates and fixes will allow normal windows scaling for GUI, but this is no longer a showstopper at all for me. Now to get mapping!
Thanks as always for the great work Resolume team!
