Artnet: Resolume-QLC-vvvv The Bermuda Triangle?
mfo
Re: Artnet: Resolume-QLC-vvvv The Bermuda Triangle?
Post by mfo »
Thanks for the advice, Zoltan.
Shared/exclusive port is of no issue between QLC+ and Resolume (which I have resorted to in the meantime).
Means at the moment only problem is: localhost missing as possible ArtNet host / IP Resolume sends to.
I guess I should post this as a feature-request.
mfo wrote:Means at the moment only problem is: localhost missing as possible ArtNet host / IP Resolume sends to.
I also don't see virtual interfaces like my VPN connection, not sure how much that would be a use case tho.
