Some Resolume 6 bugs
RJB
Re: Some Resolume 6 bugs
Post by RJB »
Zoltán wrote:In the Advanced output Input selection or Output transformation?
In Input selection the slice should not follow the opacity slider,
in Output transformation it should.
You can't check it at input and uncheck in in output, its the same option
I showed this to Daniel yesterday at ultra peru, its not supposed to do this.
The master doesnt work in the output screen but does work in the output monitor
however if you select the layer then it does work in the actual output
RJB wrote:The master doesnt work in the output screen but does work in the output monitor
I can't recreate on my setup.
Could you post screenshots, or a screen recording of everything involved so I can recreate?
Which GPU do you have?
