Audio reactive timeline position
deflost
Re: Audio reactive timeline position
Post by deflost »
... by the way, we do it the last time with isadora.
there you have to receive also a no recognizable fft animated parameter via osc, like in the pro.code bevor, and send it back to resolume as clip position also via osc......
r.h.
westfernsehen, leipzig
jimwop
Post by jimwop »
Hi all,
I’m having the same problem. I use IROSC all the time and I’m still on R5 because there is no 64 bit mac version.
I have emailed the author a few times and event offered money for them to make a 64bit version.
I have bought R6 when it came out but havent used it yet.
Help. There has to be a solution to this. Isn’t technology supposed to be going forwards not backwards.
Indigo
Post by Indigo »
IROSC 64 bit plugin, which worked on 6, does not work in 7 anymore.
Resolume, please update.
Indigo wrote: Thu Dec 05, 2019 20:57 IROSC 64 bit plugin, which worked on 6, does not work in 7 anymore.
That's a third party plugin, you need to contact the plugin developer if you'd like it to be upgraded to work with 7.
