APC mini loosing led feedback
inzieye
Re: APC mini loosing led feedback
Post by inzieye »
Zoltán wrote: Yeah, strange.
If you see your APC losing feedback mid session again, please open up the midi shortcut mapping before you do anything else and make a screenshot.
I wonder how it looks like.
Do you want my midi mapping file? Or screenshots of all my shortcuts mapping?
This happens because your other devices send midi on the same channels as the APC and Resolume doesn't check currently where the in coming message came from, and sends the feedback to all enabled outputs.
My devices are all on different channels :
APC mini channel is 1 (you can't change it)
Quneo : 12
Lemur : 6
The APC reacts to same midi notes from other devices on different channels.
inzieye wrote:Do you want my midi mapping file? Or screenshots of all my shortcuts mapping?
A screenshot of the whole GUI when you are in midi shortcut editing right after the APC loses feedback.
inzieye wrote:The APC reacts to same midi notes from other devices on different channels.
Yeah, I see the same with my APC 40, looks like they don't care about the channels, only the notes.
inzieye
Post by inzieye »
Thanks a lot for your feedback and the time you spent on this problem.
So I've got the answer, this is not a problem from Resolume but from AKAI.
I have to change my other devices midi notes and use different ones as the APC mini.
Thanks again.
Looks like this is an issue with the APC mini: http://resolume.com/forum/viewtopic.php?f=7&t=11461
