best compressor
AVI to Flash Converter
Since Resolume works 100% great with flash, im using Kibisis AVI to Flash Converter, as before I had some crashes on Resolume using certain types of AVI.........now they work 100% fine.
						To convert avi to flash I use Video to Flash Converter 4.1
It has easy settings and nice interface. And in general this prog is of a very good quality
http://www.geovid.com/Video_to_Flash_Converter/
				continuity-B
I'm not sure but I wouldn't convert video to flash for resolume as a matter of course. Need to check it out but that's really not flash's forte. That programs for making your clips streamable accross the web in a simple way.
I'd only use flash in resolume for vector graphics because they are so light weight.
If indeo or mjpeg (remember you get mjpeg free with quicktime) are not working well in resolume then something else is up with your setup.
But if it works for you, it works....
				continuity-B
Video to Flash Converter 4.1 U'll see how simple it is to use it:)Originally posted by error404
[Edited on 31-8-2005 by Vaison]
				Anonymous
Hi I have tested the AVI to flash converter but in resolume I get black thumbnales
however the flash files play perfectly when I change the time lines for these flash file resolume doesn't remember the starting point. so it get's black again after changing a deck. I also tried to sve the deck but it doesn't work out.
Does anybody know if this AVI to flash converter starts with a black 1st frame rate ? All the feedback is welcome TNX....
				Anonymous
