Midi Settings Lost + Work Around
cvanhoose
Re: Midi Settings Lost + Work Around
Post by cvanhoose »
Also had this happen to me again at one of my installation sites. Lost all my midi settings and unable to reload them from the backup. Not even the default midi presets are available in the dropdown menu.
I finally had a chance to collect the documents folder and sending you a link.
I have tried to uninstall and reinstall with the same result. When I tried to zip the folder, I received this message. I had to rename the file "45" in order to zip it.
I notice that there are 2x "45degree" presets for "lines" on all my machines.
So how do you link these folders?
Is this H: an USB drive, or a network drive maybe?
cvanhoose
Post by cvanhoose »
Zoltán wrote: Sat Jul 28, 2018 20:07 So how do you link these folders?
I do not link the folder. I just copied the documents folder to my usb device so that I could take it home and compress it for you.
All of my installations are on the c: drive with the OS.
cvanhoose wrote: Sat Jul 28, 2018 20:23
Oh, ok.
So then that's not a common thing with mfo's case.
mfo
Post by mfo »
Zoltán wrote: Sat Jul 28, 2018 09:45 Did you link the folder? With what method?
Via Symbolic Links (aka Symlinks). As discussed here: https://resolume.com/forum/viewtopic.ph ... 136#p64136
As said, it doesn't affect the other folders and their contents, only the MIDI settings.
I think mfo, and cvanhoose, are experiencing different issues.
@cvanhoose, The folder you sent us, still has the midi preset files, but they are not loadable any more by Resolume. They seem to be all 0-s in the file.
Did this start to happen after a crash or force close?
@mfo Does the factory preset-reset happen after a crash?
Could you try using Junction method instead of Symlink - with your data backed up first?
mfo
Post by mfo »
Hi Zoltan
the issue also happened (at least in the past) with un-linked folders.
And nope, no crash.
M
The only way I can get Resolume to write the factory midi presets again is to remove the config.xml.
But in this case only the missing factory presets are written again, and the modified ones and the custom presets are left untouched.
Do you have a folder sync app running like dropbox or one drive syncing to these folders?
Do you use these sync accounts on multiple machines?
jess
Post by jess »
Same problem here, presets cannot be load because they don't appear in the folder were they should be (while they are, I checked)... So I don't manage to load them.
moldywood
Post by moldywood »
Ya, in the same boat. I need Arena to launch with the APC40's mode set to Generic, but it reverts back to the "Recommended" mode of Alternative Ableton Live Mode every time I launch Arena.
